Cisco Home Community
Reply
duwebowrus
wrt54g- keep having to reset
I recently set up a wrt54g router that I got used from a friend.  I pressed the 'reset' button on the back, configured it for my computer according to the instructions on the website, and everything worked fine for a couple of days.  Then I lost connectivity, tried powercycling my modem, but had to reset and reconfigure the router again.  Worked fine again for a couple of days, then the problem repeated itself, so I reset and reconfigured again.  Is there something I'm doing wrong, or something additional I should do?
VALETLINKSYS
Re: wrt54g- keep having to reset
Do a firmware upgrade  or to isolate the issue you can try this ..
if you just turn off the router alone and able to go online : issue  might be on the router
if you turn off the modem only or modem and router : issue might be on the modem
Click the star if you find it helpful and informative :smileyhappy:
