01-12-2012 03:36 AM
Hey,
I seem to have a problem, linking my Samsung Tab to linksys router. When ever I secury my network, the tab cannot connect to the wireless system. When I unprotect the system, it's OK. I understand that I have to 'announce' my tab to the router, however when I use to option "register new device' the program asks me to connect the device with a TCP connect. The tablet doesn't have this: so question is: how can I solve my problem, I don't want to stay in unprotected mode as I also want to use my wireless connection.
thanks for any reply..
01-13-2012 02:44 PM
Let me know the model number of the router? Does any other wireless devices gets connect wirelessly when secured? Try the following step:
# Launch the web browser and on the address bar type 192.168.1.1.. So that will open up the Router setup page...
# Click on the Wireless tab create a wireless network name SSID and change Channel width to 20 MHz only and change the Channel to 6, 9, 11...Save the settings..
# Click on wireless security and select the security mode as WPA and create a password according to the requirement...
Then check the connectivity status..
01-25-2012 06:35 PM
What is the wireless settings of your router?
