Cisco Home Community
Reply
lutrasemas
How to set up a password for Linksys model# WRT54G2 V1?
I need help on setting up a passcode for my router. I have searched online but so far have not been able to find anything.
ridcully
Re: How to set up a password for Linksys model# WRT54G2 V1?
Setting up your router’s wireless security is the best way to prevent other people from using your wireless Internet connection. Your Linksys router supports three (3) of the most commonly used wireless security types: WEP, WPA and WPA2 Personal.
IMPORTANT: Before proceeding, make sure that your router is connected to your computer using an Ethernet cable so that you can access its web-based setup page.
Here is the link for setting up the security for the wireless:
http://www6.nohold.net/Cisco2/ukp.aspx?pid=93&login=1&vw=1&app=search&articleid=19073&userrole=Links...
