11-08-2009 05:56 AM
11-09-2009 12:31 PM
11-15-2009 05:15 AM
11-17-2009 07:31 AM
well after much MUCH searching, i discovered drivers that are working no thanks to linksys. i had to track down the chipset manufacturer for the device which is Ralink. and while their website is crappy, they do have drive support for vista 64 bit (and with that also win 7 64bit). installed from http://www.ralinktech.com/support.php?s=1
the model in question is the RT2500, they have drivers for the PCI and the USB versions.
had to totally uninstall the current drivers from win 7 and then install and doing the "let me choose where to look" option. the driver installed and the device is seen as a Ralink device. and so far after a week, no BSOD.
you would think that as much as they sold the WUSB54G and its sister router the WRT54G (which i also have) for last couple years that oh, hey vista 64 bit has been out for a while, lets make some working 64 bit drivers to support our device. nope. instead i buy $100 worth of equipment that can work in a 64 bit environment but isnt supported. GG linksys, wont be buying linksys products again.
