Cisco Home Community
Reply
dimolas
WAG320N Connection Problem
I have a WAG320N and my problem is that after 10-12 hours that the router is connected to the Internet, my router looses the Internet connection although the DSL line is up....
I have upgraded the firmware several times but with no luck...
here is the log of the router when it was disconnected from the  Internet.
------------------------------------------------------------------------------------------------ (from adsl_driver.htm)
--- System Information ---
Vendor: Linksys
ModelName: WAG320N
Firmware Version: 1.00.08 , 2009-08-27T19:37:13
Boot Version: 1.06
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version:  AnnexA version - A2pB023k.d21d
DSL VPI/VCI:         8/35
DSL Status:          Showtime
DSL Mode:            ADSL2+
DSL Channel:
DSL Upstream Rate:   1021 Kbps
DSL Downstream Rate: 15638 Kbps
                      Down         up
DSL Noise Margin:     5.9 dB      12.9 dB
DSL Attenuation:     22.5 dB      10.9 dB
DSL Transmit Power:  18.4 dBm     12.4 dBm
------------------------------------------------------------------------------(Logfile)
Tue, 2010-02-09 19:12:15 - Terminating on signal 15.
Tue, 2010-02-09 19:12:15 - Enter: tdb_store.
Tue, 2010-02-09 19:12:15 - tdb_store: calling tdb_update.
Tue, 2010-02-09 19:12:15 - Enter: tdb_update.
Tue, 2010-02-09 19:12:15 - LCP down.
Tue, 2010-02-09 19:12:15 - Connection terminated.
Tue, 2010-02-09 19:12:15 - Connect time 5317631.1 minutes.
Tue, 2010-02-09 19:12:15 - Sent 511764 bytes, received 1353062 bytes.
Tue, 2010-02-09 19:12:15 - Exit.
any ideas???
Wizzard
Re: WAG320N Connection Problem
As you upgraded the router's firmware,I would suggest you to reset the router and re-configure it from scratch.
dimolas
Thanks for the reply,
I have done it already.
 Also i have contact the support but they can't also figure out what is going on...
And the problem is still here :smileysad:
Wizzard
The connection drops on wired computer or on wireless computer...?
Do you have to restart the router to get the connection back..?
dimolas
The connection drops on the Router.
the wired of WiFi is up between the computers and the router
Based on the led's  the DSL Line is Up but the Internet is Down
I have contact Linksys again yesterday.. No solution provided.
I have pluged in again my SIEMENS ADSL modem and I don't have any problem
So it's a LinkSys Bug for sure
Wizzard
As you have tried all the settings on your Router and still the same problem persist, then i think it might be the problem with the router itself. I think you need to replace your router.
pablo472
Glad I'm not the only one!
I've been having exactly the same problem since buying it in December.
I've tried resetting it, I've tried reconfiguring it and also re-flashing the firmware but to no avail.
I would suggest this is actually a firmware issue....
dimolas
I have returned the router after i have contacted support and talk with them 6 times.
Now on Monday I'm waiting to receive my new router (same model)
I hope that i will not have the same problem.....
I'll just wait and see...
What have you done with your router problem  pablo?
pablo472
I tried several times last night to do live chat with a Cisco/Linksys representative but kept getting cut off.
I did manage to get out of one rep that there is no pending firmware update and he suggested I got the router replaced which he offered to do but as I kept losing connection, I returned mine back to PC World (UK) today and got it exchanged.
So far so good.... but only time will tell to see if this is an issue with all WAG320N's! :smileywink:
Tom09
Hi, I have exaclty the same problem
Every day I need to restart router to be able to connect.
It is definitely router issue, because my old one works fine.
I wish LinkSys will fix it soone. Oterwise I will be forced to return the product
